1996 Dodge Ram truck turns over but wont start
COUGUR1
  • 1996 DODGE RAM
Electrical problem
1996 Dodge Ram V8 Four Wheel Drive Manual
i have replaced the distrubutor cap, rotor, new plugs, new wires, and my truck still wont start. I had replced cap and rotor a week ago and it started fine now it wont start at alll. Any solutions to my problems?
Monday, June 7th, 2010 AT 2:58 PM
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, October 4th, 2018 AT 10:32 AM
COUGUR1
Thank you for your response, it ended up being the crank shaft sensor.
