1996 Dodge Ram engine rotates but will not start
218,000 MILES • V8 • 4WD • AUTOMATIC
IJDESIGN
I have a 96 1500 Dodge Ram 2x4. While driving it gradually lost power until dying on side of the road. Now it will not start. After having it towed home, I check the feul pump (only a year old) and it seem to be working fine. There's pressurize gas in that injector tube. Also the spark plugs are firing. And I tested all the relays. Even after spraying starter fluid into the carborator, engine will not try to start. I'm at a lost please help. By the way, the truck has 218,000 miles, is it worth fixing.
Oct 19, 2009 at 9:45 AM
  • 75,988 POSTS
Hi ijdesign and TY for the donation
You go spark-You need to verify the fuel pressure if the fuel pump is producing the correct fuel pressure and also check if the injector/s are pulsing and comeback with some testing results
Spraying starting fluid should cause it to start and die if its getting spark without the fuel pump coming on.
Oct 4, 2018 at 3:32 AM
