starting problems
DODGE
SCHULTZY
I have a 2000 Dodge 1500 p/u with 5.9L engine with 134,000mi. Some days it starts just fine and others it decides it won't work. It'll turn over but it won't sustain the ignition. I have to hold the gas pedal down for about 15min so it won't cut back off. When it does this I hear a clicking noise. I have told the Dodge dealership that works on my vehicle about this problem and they have no ideas. I have had the battery and alternator tested and both are fine. Unfortunately I am not mechanically inclined and I need help!
Feb 22, 2007 at 4:36 AM
MIKE H R
  • 3,094 POSTS
Ask the dodge dealership to check the fuel pressure and fuel filter.
Feb 22, 2007 at 8:36 AM
SCHULTZY
I finally got the truck back from Dodge and it was the throttle needed servicing. They replaced a gasket, cleaned the throttle and repaired the throttle kicker. Now it starts perfect every time. Thanks for the input!
Mar 2, 2007 at 7:45 AM
MIKE H R
  • 3,094 POSTS
your welcome, were here to help
Mar 2, 2007 at 9:12 AM
