99 Dodge 1500 starting problem
CRAIGH
  • DODGE
I have a 99 dodge 1500 5.2L driving down the road it stalled at stop sing. Will not start back up. If it does start it acts likeit is only running on a couple of cylinders. Checked fuel pressure at fuel rail (about 50 psi) coil tests good redish spark not blue. No codes come up at all. Can not keep running long enough to check anything else sensor related. Timing is close as far as I can tell. Any suggestions?
Saturday, March 3rd, 2007 AT 6:18 AM
BUBBA_KOSKI
  • 129 POSTS
Dont worry a 318 is pretty easy to work with, do you live in cold hot or wet weather? Siphon some gas out, and see if theres water, you can tell if there is. Because your truck is direct ignition and the coil packs are good, aloing with wires, plugs, then my best bet is look towards your IAC valve. Let me know
espn2006@aol. Com
Saturday, March 3rd, 2007 AT 1:34 PM
CRAIGH
  • 9 POSTS
It wasn't iac. Did comperession test range from 70-120 psi. Any other ideas?
Tuesday, March 6th, 2007 AT 4:38 PM
