1999 Dodge Neon Losing Coolant
HOCKMASM
99 dodge Neon, 130,000 miles, 4cyl Single Overhead cam, stickshift
I have been checking my coolant levels every other day and the coolant in the Resevoir Tank keeps going down.
I had it pressure checked by two different shops and they both said it was fine. Nothing wrong that they could see.
Any ideas why it is losing coolant? I am afraid to let the coolant drain all the way from the Resevoir Tank in order to see if it over heats (then take it in to a shop saying it is overheating. thinking that could help figure it out.)
Jul 29, 2007 at 7:42 AM
DPWD23
  • 136 POSTS
If the neon has a seperate Resevoir tank (connected to radiator by thin low pressure hose) remove it and check that for leaks, and replace the hose.
If its a completely closed system, you can try replacing the cap.
what ever you do, do not let it overheat! thats one of the worst things you can do to an engine.
[quote:45f37ebb49="hockmasm"]99 dodge Neon, 130,000 miles, 4cyl Single Overhead cam, stickshift
Any ideas why it is losing coolant? I am afraid to let the coolant drain all the way from the Resevoir Tank in order to see if it over heats (then take it in to a shop saying it is overheating. thinking that could help figure it out.)[/quote:45f37ebb49]
Jul 29, 2007 at 9:26 AM
HOCKMASM
it does h ave a seperate tank. with the little hose.
i will check it out. you are saying the hose my have a hole in it?
i never see any fluid under the car except condesation from the AC.
Jul 29, 2007 at 10:44 AM
Suggested Repair
Inspect the separate coolant reservoir and the small low-pressure hose connecting it to the radiator for leaks, and replace the hose if damaged. Do not allow the engine to overheat while diagnosing the coolant loss.
Conversation Summary
The owner of a 1999 Dodge Neon reports the coolant reservoir level dropping every other day. Two shops pressure-tested the system and found no leak, and no coolant is seen under the car except air-conditioning condensation. The expert advises checking the separate reservoir and its hose for leaks and replacing the hose if needed, while warning not to let the engine overheat.
