1996 Dodge Neon Thermostat Location
JENN
How do i locate and replace the thermostat in a 1996 Dodge Neon with 131000 miles.
Mar 2, 2006 at 4:11 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. :) I would suggest purchasing a manual for your vehicle. Check out the link "Repair manuals" in the blue bar to the left.
Normally one of the two large radiator hoses go to the thermostat housing. It is normally held on by a few nuts/bolts, with the thermostat located inside.
Here is a link to an online repair manual. It will do but won't replace having your own manual at your side while working.
Good luck and let us know how it goes. :?:
Mar 3, 2006 at 9:02 AM
Suggested Repair
Locate the thermostat housing where one of the two large radiator hoses connects. It is typically held by a few nuts or bolts, with the thermostat inside. Use a vehicle-specific repair manual for the replacement procedure.
Conversation Summary
The owner of a 1996 Dodge Neon with 131,000 miles asked how to locate and replace the thermostat. The expert advised using a repair manual and explained that the thermostat is normally inside the housing where one of the large radiator hoses connects, secured by a few nuts or bolts.
