1995 Dodge Neon Coolant Leak
MOLOTOV
I have a '95 Dodge neon with 130k+ miles--it is my first car, i had some problems with the gas pump but we've replaced it...
I have a new issue, about 2 days ago the car started to leak coolant after a drive (around the block or many miles) but when it's still it doesn't leak..
my question is: Can I drive it without expecting something to happen? or is this some static thing where I can just re-fill the reservoir with more coolant?
I need to see my girlfriend (which lives sort of far) and sadly that is the only transportation I have. Please if anyone reads this and have some comments or suggestion please let me know. Thank you all in advance,
Ivan :cry:
Feb 26, 2007 at 4:56 PM
SERVICE WRITER
  • 9,123 POSTS
Either you need to get that leak fixed or get a new girlfriend. You'll blow the motor driving with a coolant leak if you not careful. Fill the system up and let it idle, when it comes to temp you should be able to look around to find where it's coming from, take a pic and post it.
Feb 26, 2007 at 9:31 PM
  • 75,988 POSTS
I know what you mean about your gurl-its more important than the ride been there 40yrs ago, now she's no longer with me except the kids. Love is LOve huh!
Options: Catch the bus or take a chance with these-load up 10gals of water in the trunk, when that idiot lite says Hot or goes/ comes up to half point, stop and refill you only die once.
Or take Mr.SW's advise and comeback with the location so that we can help you get to your gurl in life with no problems.
The way you sounded its like a freeze plug beside the block
Feb 27, 2007 at 5:28 AM
MOLOTOV
Thank you both for replying my message, I will try to see what I can do and also I will take a picture of the leak and explain a little further if needed...
thanks again.
ivan
Feb 27, 2007 at 7:48 AM
SERVICE WRITER
  • 9,123 POSTS
No Problem-O!
https://images.2carpros.com/forum/automotive_pictures/30961_Bigsmilepig_6.jpg
Feb 27, 2007 at 10:01 AM
Suggested Repair
Do not keep driving with a coolant leak, as overheating can damage the engine. Fill the cooling system, idle until it reaches temperature, and inspect to locate the leak; a freeze plug beside the block is one possible source. Photograph the leak location for further diagnosis before driving long distances.
Conversation Summary
The owner of a 1995 Dodge Neon reports coolant leaking after driving but not while parked, and asks whether it is safe to drive or simply refill the reservoir. Experts warn that driving with a coolant leak can overheat and damage the engine. They recommend filling the system, idling to temperature, locating the leak, and posting a photo. One reply suggests a freeze plug beside the block as a possible source.
