2000 Dodge Neon coolant leaks
CAROLITA
Engine Cooling problem
2000 Dodge Neon Automatic
My son ws driving my car when it started to smoke (white). He immediately shut it off, found out there was no oil or antifreeze and filled both. But now the antifreeze leaks out from behind the engine block. what can it be? We do not see any hoses that have come off.
May 18, 2009 at 5:29 AM
LEGITIMATE007
  • 5,121 POSTS
could be comming from several little ports on the block called freeze plugs or he may have warped the head and or blown the head gasket, this is why white smoke is comming out and leaking and three, the heater hoses could have burst from the excessive heat
May 18, 2009 at 5:41 AM
