1998 Dodge Neon Coolant Leak at Housing
BAWM81
Good Morning. I have a 1998 Dodge Neon 2.0 SOHC. I have a coolant leak that I am not sure how to repair, mostly what parts I need though. The leak has become somewhat bad because i have to add fluid every 2-3 days. The leak is at the connection between the Head and the main hose where the Radiator cap is. Can anyone tell me what i need to do so that i can solve this problem and not have my car overheat anymore. BTW, I'm not sure if it matters but i had that problem with the cooling fans not coming on for several months before this, but they are fixed now.
Jun 26, 2006 at 10:57 AM
VANDRAGON
  • 298 POSTS
sounds like a loose hose clamp or bad radiator cap.
Jun 27, 2006 at 3:50 AM
BAWM81
Ok, let me be a bit more clear here. I see where the leak is, it is coming from the conection of the Main Hose with the Radiator cap, to the Engine, where the hose does not clamp in but is bolted in. I have checked both the radiator cap and all the clamps and they have replaced all that are bad. Can anyone tell me how and what to replace to solve this problem.
Jul 5, 2006 at 1:39 PM
HEAVYDUTY
  • 60 POSTS
drain coolant, unbolt rad cap/thermostat housing from the head, clean surfaces,install new gasket and reassemble then refill with good coolant
Sep 9, 2006 at 3:10 PM
BAWM81
[quote:20503241ce="heavyduty"]drain coolant, unbolt rad cap/thermostat housing from the head, clean surfaces,install new gasket and reassemble then refill with good coolant[/quote:20503241ce]
Thanks heavyduty, I wasn't quite sure if I would have to go more in depth than that. I appreciate your reply.
Sep 18, 2006 at 7:04 AM
Suggested Repair
Drain the coolant, unbolt the radiator-cap/thermostat housing from the cylinder head, clean the mating surfaces, install a new gasket, reassemble, and refill with the correct coolant.
Conversation Summary
The owner of a 1998 Dodge Neon 2.0 SOHC reported a coolant leak at the bolted connection between the upper hose/radiator-cap housing and the engine, requiring fluid every few days. Clamps and the radiator cap had already been checked. The recommended repair is to drain the coolant, remove the thermostat housing, clean the surfaces, install a new gasket, and refill.
