I have a P0551 code Power steering code?
BUSGIL
I have a 2000 dodge neon. I have a P0551 code. Power steering code. I reset it it goes away unit i reach Freeway Speed. What can be wrong? the Power Steering switch or something else?
thanks
Jan 16, 2006 at 2:17 PM
CHEVY22
  • 1,375 POSTS
the code p0551 is a power steering switch failure the switch is located on the steering rack , if you have reset the pcm several times and the code keeps coming back this is most likely the problem
let me know
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
Feb 24, 2007 at 4:29 PM
Suggested Repair
Replace the power steering pressure switch on the steering rack. P0551 indicates switch failure, and the code returning after repeated PCM resets at freeway speed points to a faulty switch.
Conversation Summary
The owner of a 2000 Dodge Neon reports a P0551 power steering code that clears after a reset but returns at freeway speed, and asks whether the power steering switch is the cause. The expert identifies P0551 as a power steering switch failure, notes that the switch is located on the steering rack, and says a code that keeps returning after multiple PCM resets most likely means the switch is faulty.
