what do u guys thing is the problem. will the 02 sensor fix it??
btw i have a 95 dodge neon 114k miles.
Return the car to the shop that replaced the catalytic converter. Have them check the oxygen sensor waveform and confirm the sensor was not damaged or poorly connected during the converter replacement. Do not assume code 21 means a failed oxygen sensor, since a wiring problem or PCM fault is also possible.
A 1995 Dodge Neon with 114,000 miles slows as if it is about to die while driving. A catalytic converter was replaced, but the problem returned on the highway before the car recovered. Code 21 led the owner to suspect the oxygen sensor. The expert advised against assuming that diagnosis and recommended having the installer check the sensor waveform and connections, noting that wiring or a PCM problem could also be involved.
