2000 Dodge Neon P0455 EVAP Leak
ANDREACAMERON
I found out that the code P 0455 means evaporative Emission Control System Leak Detected.
Could someone please explain to me what this means and how do I fix it? Thank you so much.
Sep 10, 2007 at 1:03 AM
SERVICE WRITER
  • 9,123 POSTS
That code means large leak. A missing or loose gas cap may cause it, a component failure, fuel tank neck, evap hose disconnected are some possiblities. Check the fuel cap and make sure it has no cracks in the gasket and is tightend down good. Otherwise a smoke machine will need to be used to find it.
Sep 10, 2007 at 1:11 AM
Suggested Repair
Check that the gas cap is tight and its gasket is not cracked. If the cap is good, have the EVAP system smoke-tested to find a large leak such as a disconnected hose, fuel tank neck issue, or failed component.
Conversation Summary
The owner of a 2000 Dodge Neon asked what code P0455 means and how to fix it. The expert explained that it indicates a large evaporative emissions leak, which may be caused by a missing or loose gas cap, a cracked cap gasket, a fuel tank neck problem, a disconnected EVAP hose, or a failed component. They recommended checking and tightening the gas cap first, then using a smoke machine to locate the leak if needed.
