2003 Dodge Neon error code
51,000 MILES • 4 CYL • 2WD • AUTOMATIC
AMBRIT07
  • 5 POSTS
on my 2003 dodge neon i have the following error code P0441, what does it mean and is it easy to fix and how ?
Mar 21, 2008 at 2:38 AM
MASTER TECH DAN
  • 83 POSTS
that is an evaprator code did you get gas while the car was running check your gas cap then you can disconnect the battery to reset the comp if it comes back on you need to have the system smoked with a machine
Mar 25, 2008 at 2:51 PM
