2001 Dodge Neon Power Steering Sensor Code
SLNELSON1977
I have a 2001 dodge neon with 95,053 miles and the check engine light came on. The code is 0551 and it says that the power steering pressure sensor curcuit range/performance. Do I need to replace the sensor? And where can I get the part to fix it?
Feb 26, 2007 at 8:49 AM
CHEVY22
  • 1,375 POSTS
yes it sounds like it is shorted internally , you can get the part at any parts store , i prefer the dealer or napa , very easy to install also
thanks, jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others
Feb 26, 2007 at 10:13 AM
Suggested Repair
Replace the power steering pressure sensor. The expert believes it is shorted internally. The part is available at a dealer or NAPA and is described as easy to install.
Conversation Summary
The owner of a 2001 Dodge Neon with about 95,000 miles has a check engine light and a code for power steering pressure sensor circuit range/performance, and asks whether the sensor must be replaced and where to buy it. The expert says the sensor sounds shorted internally, recommends buying it from a dealer or NAPA, and notes that installation is easy.
