1995 Dodge Neon Code 21 O2 Sensor
PITAX1
i have a code 21 on a 95 neon, do you know what this is?
Mar 23, 2007 at 3:47 AM
MERLIN2021
  • 17,250 POSTS
21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
Mar 27, 2007 at 7:16 AM
VASCOTT76
WILL A CODE 21 ALSO CAUSE THE CAR TO HERK AND RUN ROUGH NOT ACCELERATE ALSO AND IS CODE 21 THE UPPER O2 OR LOWER BY THE CATALYTIC CONVERTER
Apr 18, 2008 at 5:30 AM
Suggested Repair
Test or replace the oxygen sensor. Code 21 indicates the sensor signal does not change and stays around 4.3-4.5 volts, which usually points to a faulty oxygen sensor.
Conversation Summary
The owner of a 1995 Dodge Neon asked what code 21 means. The expert said the oxygen sensor signal does not change and remains at 4.3-4.5 volts, so the sensor is probably bad. The owner also asked whether the code causes jerking, rough running, and poor acceleration, and whether it refers to the upstream or downstream sensor, but those follow-up questions were not answered.
