1998 Dodge Neon Shaky Steering
TREKINOUS
  • 28 POSTS
Hey, I have a 1998 Dodge Neon 2.0L SOHC, automatic. While driving above 80km/h the steering wheel begins to shake violently. The steering wheel also doesn't sit stright while driving stright, it is slanted heavily to the left. The car also tends to wander the road a lot. Everything in the front end seems to be fairly solid and tight. Could it be that the wheels are simply off balance?
Any advice is appriciated.
Jul 30, 2007 at 11:42 AM
MAGICKALNAN
  • 5 POSTS
[quote:abaf8ebee9="Trekinous"]Hey, I have a 1998 Dodge Neon 2.0L SOHC, automatic. While driving above 80km/h the steering wheel begins to shake violently. The steering wheel also doesn't sit stright while driving stright, it is slanted heavily to the left. The car also tends to wander the road a lot. Everything in the front end seems to be fairly solid and tight. Could it be that the wheels are simply off balance?
Any advice is appriciated.[/quote:abaf8ebee9] I have 2004 neon that does the same thing and went to get and alignmet this morning and found out that the bushings in my lower control arms are out. So you might want to check them... :idea:
Sep 12, 2007 at 4:57 AM
ANDY B
I drive a 1999 Neon and I had the same problem. Every time I hit about 55km and 85km my steering got shakey and it pulled to the right a bit. Turns out that my front right rim was bent and the wheights on it were putting it off balance. I decided to get all 4 tired balanced just to be safe and its only about $15 per wheel. The car drives really straight and doesnt shake any more. Hope this helps!
Nov 7, 2007 at 10:04 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9cce3b2452="Trekinous"]Hey, I have a 1998 Dodge Neon 2.0L SOHC, automatic. While driving above 80km/h the steering wheel begins to shake violently. The steering wheel also doesn't sit stright while driving stright, it is slanted heavily to the left. The car also tends to wander the road a lot. Everything in the front end seems to be fairly solid and tight. Could it be that the wheels are simply off balance?
Any advice is appriciated.[/quote:9cce3b2452]
The 1st step tire balance
Have the tires checked and balanced
As for wandering if you say the front end tested ok
Its alignment time
So have the front end align and the tires checked and balanced
Good luck
Nov 7, 2007 at 10:29 AM
Suggested Repair
Have the tires inspected and balanced, then perform a front-end alignment. If the shake or wander continues, inspect the wheels and rims for damage and check the lower control arm bushings.
Conversation Summary
The owner of a 1998 Dodge Neon reported violent steering-wheel shake above 80 km/h, a wheel that sits heavily left while driving straight, and road wander, despite a front end that felt tight. Other Neon owners reported similar symptoms from worn lower control arm bushings or a bent, unbalanced rim. The expert recommended balancing the tires first and then aligning the front end.
