1995 Dodge Neon wont start
AUGUSTINE
  • 1995 DODGE NEON
  • 4 CYL
  • 134,567 MILES
I have a dodge neon, for some reason it wont start. Ive tried all the basic things like the starter, computer, what are some other things I should try? It doesnt turn over at all it might be a wiring thing but I dont kno where to start.
Tuesday, February 5th, 2008 AT 8:05 PM
BMRFIXIT
  • 19,053 POSTS
Have you checked the fuses and relay
Tuesday, February 5th, 2008 AT 9:02 PM
FRANK SKEA
  • 5 POSTS
Check the main ground wire from the battery to the frame. These grounds seem to be lite. It goes from the battery and attachs to the frame with the starter bolt. Fairly easy to see and fix if problem.
Wednesday, February 6th, 2008 AT 6:26 PM
AUGUSTINE
I, ve checked those so its somthing else?
Thursday, February 7th, 2008 AT 11:25 AM
BMRFIXIT
  • 19,053 POSTS
Did you check neutral safety switch on the tranny
Thursday, February 7th, 2008 AT 1:34 PM
AUGUSTINE
Checked that to still didnt work
Saturday, February 9th, 2008 AT 6:35 PM
BMRFIXIT
  • 19,053 POSTS
How did you check the neutral safety switch !
Do you have power in and power out
or what
let me know
Sunday, February 10th, 2008 AT 6:40 PM
TERRYGL
There is a wire on the starter called a fusable link if it burned out wa la no start. Hope this helps
Saturday, July 19th, 2008 AT 6:34 PM
