1995 Dodge Neon car cranks will not start
BHAHR
  • 1995 DODGE NEON
1995 Dodge Neon 4 cyl Manual 200000 miles
I drove my son to preschool this morning, drove home( 5 minutes away) went to the house waited about 30 minutes to take my older son to school and it would not start. It cranks but will not turn over.
Monday, March 15th, 2010 AT 12:11 PM
LEGITIMATE007
  • 5,121 POSTS
You will need to verify which component you are missing. Fuel or spark.
Monday, March 15th, 2010 AT 12:23 PM
LEGITIMATE007
  • 5,121 POSTS
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Monday, March 15th, 2010 AT 12:24 PM
LEGITIMATE007
  • 5,121 POSTS
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Monday, March 15th, 2010 AT 12:25 PM
BHAHR
I do not believe that is is fuel. I know I have gas in the car and have not recently had any trouble w/ injectors.
Monday, March 15th, 2010 AT 12:32 PM
LEGITIMATE007
  • 5,121 POSTS
I understand, but if the pressure regulator, isnt getting fuel to the injectors, or the pump isnt working anylonger. Or the fuel filter is clogged to where it has a hard time starting, these can all of a sudden be a possibility but we wont know until it is tested.
Monday, March 15th, 2010 AT 12:36 PM
BHAHR
I had someone check and he said it is not getting any spark. It is definitely getting fuel, no spark. Would this be the coil pack? This is my second 95 neon and I'm thinking this may have happened to me before with my other Neon.
Monday, March 15th, 2010 AT 2:45 PM
LEGITIMATE007
  • 5,121 POSTS
Yes it can be the coil pack, also I would check the crank sensor, as both of these can be at fault, before you condemn the coil pack, check for voltage going to the pack
Monday, March 15th, 2010 AT 7:09 PM
