1996 Dodge Intrepid O2 Sensor Cost
DIANNECNY
1996 Intrepid - 130,000 mi. "Check Engine" light comes on and off -- was told I needed an Oxygen Sensor - runs rough, but much better traveling over 50 mph. Can you please tell me exactly what this part is and an approximate cost to replace? Thanks.
May 1, 2007 at 12:58 AM
BACKYARDMECHANIC
  • 337 POSTS
The O2 sensor monitors the oxygen level of the exhaust from the motor. The cars computer recieves a voltage signal from the O2 sensor and uses this signal along with other signals it recieves to adjust the air/fuel mixture to current conditions. If the O2 sensor detects a large or small presents of oxygen in the exhaust the computer will make the necessary adjustments. The price for the part (no labor) varys and starts aprox $50 and up.
May 2, 2007 at 4:29 AM
Suggested Repair
If diagnosis confirms a faulty oxygen sensor, replace it. The sensor monitors exhaust oxygen so the computer can adjust the air-fuel mixture. Parts start around $50; labor is extra.
Conversation Summary
The owner of a 1996 Dodge Intrepid with 130,000 miles reported an intermittent check engine light and rough running that improved above 50 mph, and asked what an oxygen sensor is and what replacement costs. The expert explained that the sensor measures exhaust oxygen and sends a voltage signal used to adjust the air-fuel mixture, with parts starting around $50 before labor.
