1997 Dodge Intrepid Stalls and O2 Codes
NCASTRO
I have a 1997 Dodge Intrepid 3.5 and the Check Engine light keeps coming on and off. I took it to an auto part store that did a diagnostic on it. It came out with the following codes: P0160 - 02 sensor check no activity & P0137 02 sensor circuit low volts. The guy told me I needed to replace my 02 sensor. Where is that located in my car? Will that help my car from turning off every once in a while?
Jun 13, 2007 at 5:52 AM
OLDTECH2
  • 64 POSTS
Several O2 sensors on it. You should have 1 sensor in each ex manifold, then 1 sensor in each pipe behind the cat converter.
The shutting down could be several sources. You'll need to check the codes on it. Mine did the dieing thing until I figured out about the capacitor that Chrysler put in the wire harness ahead of the coil pack. It will give you a code for voltage loss when peak dwell is required.
Chrysler says that you have to buy the engine harness to repair it. I simply got a condenser from an old point type ign and soldered it in place of the capacitor. The car has been running without a problem since.
Jul 14, 2007 at 1:20 PM
Suggested Repair
Locate the O2 sensors—one in each exhaust manifold and one in each pipe behind the catalytic converters—and address the stored O2 codes. For intermittent shut-down, also inspect the capacitor in the wiring harness ahead of the coil pack; a failed capacitor can cause voltage loss under peak dwell. Chrysler's repair is a new engine harness; one technician substituted a points-ignition condenser soldered in place of the capacitor.
Conversation Summary
The owner of a 1997 Dodge Intrepid 3.5 reports an intermittent check-engine light and occasional shut-downs. A parts-store scan showed P0160 (O2 sensor no activity) and P0137 (O2 sensor circuit low voltage), and they were told to replace the O2 sensor. The expert notes sensors in each exhaust manifold and behind each catalytic converter, and says stalling can have several causes. On a similar Chrysler, a capacitor in the harness ahead of the coil pack caused voltage-loss codes and dying; replacing it with a points-ignition condenser fixed the stall.
