2000 Dodge Intrepid Stalls When Slowing
WILBER
  • 5 POSTS
I have a 2000 Dodge Intrepid with about 107,000 miles and when I am driving at low speeds (25-50 mph) the car is putting out about 1500 rpms but may shoot up to the normal 2000 rpm range. When driving on the highway the rpms are closer to 2200-2500rpm, driving 65-75mph. Most importantly, when slowing down to make a turn or at a stop, the car will once and a while stall. I am able to start the car after a couple turns, but have been making turns at a slow speed and lose my power steering and brakes. A little tough to navigate if there is an uncoming car!!
Hope someone can help!
Feb 20, 2006 at 12:08 AM
JPAM
  • 307 POSTS
your rpm sounds about normal, as for the stalling when slowing up. The cheapest thing to start with is the fuel filter& with that milage it just might be. I had a car do the same thing when i had to stop quick it would stall. Can't explan it but thats the only thing i changed and it worked... Hopefully u can get this lucky too... If u got any ?? replacing filter send reply.. Good luck Jess S.
Feb 21, 2006 at 5:10 PM
HARLEY70
EGR Valve?
Feb 27, 2006 at 4:15 AM
Suggested Repair
Start with the fuel filter. With about 107,000 miles, replace or check it first as the cheapest step for stalling when slowing or stopping.
Conversation Summary
A 2000 Dodge Intrepid with about 107,000 miles sometimes stalls when slowing for a turn or coming to a stop, then restarts after a couple of tries. Highway and low-speed RPM readings were described as roughly normal. The expert recommended starting with the fuel filter, noting a similar stall-on-quick-stop case that was fixed by replacing it. A later comment asked about the EGR valve, but that was not confirmed.
