1995 Dodge Intrepid
ESCOR
  • 1995 DODGE INTREPID
  • 6 CYL
  • 150,000 MILES
I need help, when car is running cold, it has low idle and is sluggish.
when vehicle is wam, it runs fine.
what could be suggestions to check?
Thursday, February 11th, 2010 AT 4:29 PM
  • 109,885 POSTS
Has the check engine light turned on? Have you checked for vacuum leaks?
Saturday, February 13th, 2010 AT 7:53 PM
ESCOR
Hello joe
thank you for response,
i have checked for leaks, and the check engine light
does eventually come on, but goes off after running for a while. I also figure out how to check codes
if I did it properly I get code 32 - egr problem.
Is this common for this problem and would changing the egr valve solve this
thank you for your time
rich
Monday, February 15th, 2010 AT 11:46 PM
