I have a 1994 Dogde Intrepid 3.3 with 202,000 that is stalling only when it is hot. If I allow it to cool down it will start and run with out any problems then stall when it warms up. I have replaced the timing chain, fuel pump, plugs and wires, and fuel pressure regulator. I have treated the gas for water and have added additional fuel and the problem still exsits. I also have replaced the gas cap thinking it was vapor locking. Also replaced is the cam and crank shaft sensors. All of this work has been done with in one year. At a loss!
Thanks,
Brian
Thanks,
Brian
Mar 13, 2007 at 10:52 AM
