code P0432
TERRYC9
I have a 1999 Intrepid 2.7 115000 miles.CE light is on with code P0432.I disconnected the battery but code is still there.Front and rear sensors are switching about the same and pretty fast.Do I need a scanner to clear this code?I checked for codes without starting the car after disconnecting the battery.Will the bad cat show up without starting?
Sep 13, 2007 at 9:25 AM
  • 75,988 POSTS
[quote:de675a240c="terryc9"]I have a 1999 Intrepid 2.7 115000 miles.CE light is on with code P0432.I disconnected the battery but code is still there.Front and rear sensors are switching about the same and pretty fast.Do I need a scanner to clear this code?I checked for codes without starting the car after disconnecting the battery.Will the bad cat show up without starting?[/quote:de675a240c]
P0432....Main Catalyst Efficiency Below Threshold (Bank 2)
O2's are they OEM parts? it takes a scan tool to clear code/s.
Sep 13, 2007 at 11:16 AM
