2001 Dodge Intrepid cam shaft sensor
112,003 MILES • 6 CYL • 2WD • AUTOMATIC
MMARIO
when I start my car it runs fine, but when it warms up and i go on the freeway at 55 it starts to sputter and i have to rev up the engine in nutruel. It also dies out on me from time to time and the idle goes up by itself? can you tell me if its the cam shaft sensor and where is it located? What could be wrong?
Jun 24, 2010 at 2:42 AM
2CARPRO JACK
  • 11,533 POSTS
It could be thecam sensor, or maybe the crank sensor.Has the check engine light ever come on when it is doing this? If so have the PCM (computer) scanned for any stored codes that may lead to the fix.
Jun 25, 2010 at 12:51 AM
MMARIO
yes but i had it checked and they say its one or the other. I replaced the crank shaft sensor and it does the same thing still.
Jun 25, 2010 at 3:50 AM
2CARPRO JACK
  • 11,533 POSTS
cam sensor location
2.7 liter engine is front side of left cylinder head
3.2 & 3.5 are on the front of the engines timing case cover
Jun 28, 2010 at 12:44 AM
WILEYBUILDER
I change my cam sensor and it still dose the same thing it won't run but when I unplug it the car will run but real rough where is the crank sensor at
Jul 5, 2010 at 6:50 AM
2CARPRO JACK
  • 11,533 POSTS
I thought you already replaced it? Lower side of the block on passenger side, near the trans bellhousing
Jul 7, 2010 at 1:24 AM
