1997 Dodge Intrepid No Start
BINSWANGER
70,000 miles - dodge intrepid 1997 3.3L
sometimes car won't start 1st time (have to turn key 2-3-4 times)--it makes no noise at all or just a slight click)
gas warning lite flashes on dash when tank is full and gas guage on dash works intermittently
Dec 21, 2006 at 7:19 AM
GARFIELD
  • 197 POSTS
Have you had your battery checked lately, a bad or low charged battery can give you the no cranking condition, as can loose or corroded terminals. Secondly by the sound that you have to turn the ignitions sometimes 3-4 times to get it to start could mean that the ignition switch is going bad, a easy way to check it is to connect a voltage meter(commonly called a DVM(digital voltage meter) to the start terminal on the starter(it is the small wire attached at the starter terminal), then attempt to start the car and see if you get 12 volts at the starter while attempting to start. If you get 12 volts at the start wire while trying to start but the car willl not start and the battery has tested good, then the starter is probably going bad. Hope this helps
Later,
Gary
Dec 22, 2006 at 12:47 PM
Suggested Repair
Check battery charge and cable terminals for corrosion or looseness. If the battery tests good, measure for 12 volts at the starter start wire while cranking; voltage present with no crank points to a failing starter, while no voltage points to a failing ignition switch.
Conversation Summary
A 1997 Dodge Intrepid 3.3L sometimes will not crank on the first key turn and makes no noise or only a slight click. The fuel warning light also flashes with a full tank and the gauge works intermittently. The expert recommends checking the battery and terminals, then testing for 12 volts at the starter start wire to distinguish a bad ignition switch from a failing starter. The fuel-gauge issue was not addressed.
