Brake light switch wiring diagram - no brake lights?
BLADESDAD
  • 6 POSTS
I didn't see that anywhere on the peddle I ordered one last night it should be in today so I'm hoping thats what it is thank you so much for your help
Sunday, July 28th, 2019 AT 5:51 PM (Merged)
BLADESDAD
  • 6 POSTS
  • 1995 DODGE DAKOTA
  • 4 CYL
  • MANUAL
  • 186,000 MILES
I just bought a 95 Dodge Dakota and found out my break lights were not working then I found a wire that was unhooked plugged it up and my break lights come on and wont go off. I pulled the peddle up and it had no effect. Can you help please and thank you
Test the brake switch if okay try adjusting it
BLADESDAD
  • 6 POSTS
Where would I find the break switch?
Just following the brake pedal arm till it meets the brake support bracket it's right there.
RSANDS23
  • 1998 DODGE DAKOTA
  • 6 CYL
  • 10,300 MILES
The other week both my brake light and ABS light came on in my truck. I checked the pads, the fluid is not leaking at the master cylinder or at the wheels. The truck still stops on a dime. I am confused as to what it could be. The same time these lights came on my speedometer stopped working too. It is not recording mileage or anything.
JDL
  • 16,098 POSTS
Because of the safety issue with the abs system, you need to get it checked out.
On the rwal system, that sensor is in the differential, the magnetic sensor can pickup all kinds of metallic debris. I believe the signal for speed and distance also comes from this sensor. You need to get it looked at.
