2000 Dodge Caravan Ticking and Brake Shake Fix
BISHOPP
I have a 2000 Dodge Caravan, V6 3.0 and it makes a ticking noise after I start it and it is warming up. The brake pedal also shakes when I brake no matter how fast I am going. What could it be?
Jul 1, 2007 at 6:07 PM
BRUCE HUNT
  • 3,754 POSTS
Warped rotor on the brakes is the problem with the pedal play. I would consider either having them turned or replacing with new. Surprisingly they are not that expensive.
Ticking noise, goes away when the engine is warm? I might look to see if something is loose and flapping around with the belts or fan. It could be a belt that is seperating.
Jul 2, 2007 at 4:47 AM
Suggested Repair
Have the brake rotors turned or replaced to address the shaking pedal. For the ticking during warm-up, inspect the belts and fan area for something loose or a belt that is separating.
Conversation Summary
The owner of a 2000 Dodge Caravan reports a ticking noise after startup while the engine warms and a brake pedal that shakes at any speed. The expert attributes the pedal shake to warped rotors and suggests turning or replacing them. For the ticking, the expert suggests checking for something loose around the belts or fan, or a belt that is separating.
