1995 Dodge Caravan Brake Lights Stay On
KENNY_09
well i have been having trouble with my break lights. My lights stay on when i turn off the car and will not turn off for some reason. I have had to keep recharging the battery because it keeps going dead from the break lights not going off.
Feb 12, 2007 at 6:47 AM
BOOTDOG
  • 665 POSTS
see if your brake light switch is sticking. it's underneath the dash on the brake pedal rod. when you depress the brake, the brake pushes the switch for the light to come on. chances are the switch is stuck on. if it is sticking and it does release, get a new one anyway , because it'll happen again
Feb 27, 2021 at 5:57 AM
Suggested Repair
Inspect the brake light switch under the dash on the brake pedal rod. If it is stuck on or sticking, replace it so the lights turn off and stop draining the battery.
Conversation Summary
The owner of a 1995 Dodge Grand Caravan reports that the brake lights stay on after the vehicle is turned off and repeatedly drain the battery. The expert advises checking the brake light switch on the brake pedal rod under the dash, which may be stuck on, and replacing it even if it releases so the problem does not return.
