1996 Dodge Caravan brake lights dont work
GERALD1964
Brakes problem
1996 Dodge Caravan 6 cyl Two Wheel Drive Automatic
my brake lights dont work but my third brake light works. replaced the fuses and light blubs still dont come on.
Mar 25, 2009 at 3:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty brake light switch. Switch is mounted at top of brake pedal arm.
Thanks for using 2CarPros.com!
Mar 25, 2009 at 3:06 PM
CARADIODOC
  • 34,416 POSTS
Only the center high-mount brake light and license lamp use a common sense circuit. All other interior and outside lights are run by the Body Computer. If the wipers work, the fuse is not blown. The computer is stuck up against the firewall in front of the brake pedal. It is not a do-it-yourself item, in fact, it's miserable for the professionals, and it has a high failure rate. Sorry to say, but this is why I'm sticking with my 1988 Grand Caravan, . . . no computers and extremely reliable.
caradiodoc
Mar 26, 2009 at 8:51 PM
