If when sitting in park and you put your foot on the brake and remove it to get the click to happen and can get it over and over and it is directly related to the brake being applied then it is the solenoid. They are normally pretty noticeable so if this is what it is doing then it is normal.
As for the chimes, this single chime after the initial ones is an indication that a system has been disabled like the seat belt chime. Does the chime go off if the seat belt is not fastened when driving? If not then that is what that chime is indicating.
If this is not the issue then the only way to find out is hook up a scan tool and monitor the messaging system and it should tell you what system has been disabled.
If the clicking is not related to the brake being applied then please get a recording of the noise and we will be able to better determine what it is. Thanks
Thursday, March 26th, 2020 AT 6:16 PM
