The car starts great but there is a little clicking or ticking noise while it is warming up. Is this normal, or what should I look for?
Sep 17, 2008 at 2:51 PM
DOCFIXIT
✓Experienced Mechanic
Is ticking comming from engine? Does it vary with RPM? If so lifter tick. Does it go away when hot?
If yes to above change oil and filter increase viscosity slightly and you may want to Marval Mistery oil great stuff will clean out lifters.
Sep 18, 2008 at 1:44 AM
AMYSTEN
MEMBER
Thanks it's due an oil change anyway
Sep 18, 2008 at 2:38 AM
DOCFIXIT
your welcome let me if this helps.You can get Marvel at Walmart and it is very good at cleaning injectors add to fuel.
