2001 Dodge Caravan Vibration
FERRY
hi, i have a 2001 sport,3.3engine caravan with 158000 km...it started taking a lot of gas..and it wobbles when i drive my staring wheel was vibariting and so was I. the whole car basically. one day it started shaking really fast and then the engine sign poped up. what can be the cause of all this? and also when i start the car sometimes it makes a noise as if a bird is chirping...please answer my question ASAP cause my mechanic cant figure it out
Jul 20, 2007 at 3:19 PM
  • 75,988 POSTS
[quote:7a935f3500="ferry"]hi, i have a 2001 sport,3.3engine caravan with 158000 km...it started taking a lot of gas..and it wobbles when i drive my staring wheel was vibariting and so was I. the whole car basically. one day it started shaking really fast and then the engine sign poped up. what can be the cause of all this? and also when i start the car sometimes it makes a noise as if a bird is chirping...please answer my question ASAP cause my mechanic cant figure it out[/quote:7a935f3500]
engine sign poped up: Get the OBD2 scanned for code/s and comeback with it.
For the wobblely thingy-have the front end check. you never know something might just come out while driving-unsafe.
Jul 20, 2007 at 4:46 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like a serious vacuum leak is the cause of the vibration and engine light
Nov 30, 2007 at 2:14 AM
Suggested Repair
Scan the vehicle for OBD-II codes and report the results. Have the front end inspected for the vibration and wobble, and check for a serious vacuum leak that could cause rough running and the check-engine light.
Conversation Summary
The owner of a 2001 Dodge Caravan with a 3.3L engine reports high fuel use, steering-wheel and whole-vehicle vibration, a check-engine light after severe shaking, and an occasional chirping noise at startup. One expert advises scanning for codes and inspecting the front end for safety. Another suggests a serious vacuum leak as a possible cause of the vibration and engine light.
