Serpentine Belt Noise
DODGE CARAVAN
BKAYS209
I have a 1998 Dodge Grand Caravan with 120,000 miles and is 3.3L engine. In Feb I had taken the car to a delaer for excessive noise and overheating. They replaced my water pump, serp belt, ac comp, and thermo gasket. After driving about 75 miles back home to another state, I started to hear a slight noise coming from the belt again. When I took it to someone, they replaced the belt and the tensioner. The noise went away for about 20 miles, then came back. They then cleaned all pulleys and said it wasn't making noise. Sure enough, after 10 miles, noise came back. They replaced the gasket again thinking it was that but it wasn't. They believed it had something to do with the water pump so they advised me to take to the dealer because this would be warrantied since I just had it replaced. The dealer is telling me I need to replace the AC lines because they are spraying and/or leaking on the serp belt and that's where the noise is coming from. Of course, it's the one thing that wouldn't be warrantied so they would make more money off me. I find it hard to believe that the other 2 places I took it to had nothing to say about the AC lines and no one has seen any fluid on the belt. Is this even possible? I'm at a loss for what to do.
Jul 13, 2007 at 12:42 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds more like there is a bad accessory bearing that begins to make noise when it gets hot, could even be the idler bearing
Jul 15, 2007 at 1:16 AM
BKAYS209
I know you said it sounded like a bad bearing but now someone is telling me it's something bad going in the alternator. Would I still have a good battery if it was my alternator? Someone else said I might just need to replace the mount that when they replaced the water pump and serp belt before, the mount went bad. Does any of these things sound logical to you?
[quote:dea8dec564="2CarPro Jack"]Sounds more like there is a bad accessory bearing that begins to make noise when it gets hot, could even be the idler bearing[/quote:dea8dec564]
Jul 25, 2007 at 6:42 AM
2CARPRO JACK
  • 11,533 POSTS
I dont think the mount has anything to do with it.An Alt bearing can go bad and the alt will still work,
Jul 25, 2007 at 10:53 AM
