how to change wheel bearing
SMM111
i have a 2000 grand caravan,84000mi. 3.3 eng. and when I put it in rev. or drive. it makes a clunking noise coming from my right tire.i took it off and the tire spun freely while lifted off the ground and this is a front wheel drive, so wheel bearing right? what do i need to fix it
Jun 21, 2007 at 7:30 PM
E40WATER12
  • 522 POSTS
I would check youre strut mounts, For play, Also ball joints, Outter tie rod ends. If youre wheel bearing is no good, If u turn a corner it will grind, Like metal to metal sound, Even driving down the road, It will be noticed as well.
Jun 25, 2007 at 9:20 PM
