2002 Dodge Grand Caravan Whining Noise
QQKLTB
I'm getting a wine-ing sound when I excel, first thing I thought it was the Transmission. I took it to AAMCO and was told the it was not the Transmission. I then took it to a local total car care center and was told it was the trans. What puzzles me is the sound is audible when driving, in nuetral and in park. AAMCO told me it sounds like it's coming from pully area where the belt is. If it's not the Transmission what could it be?
Feb 10, 2006 at 1:11 AM
PEPPERMRJ
  • 1,158 POSTS
My guess would be the serpentine belt, it's tensioner pulley, or one of the other belt driven accessories (alternator, power steering pump, etc). Remove the belt and run the engine very briefly. No whine means you are on the right track. Spin the pulleys by hand and feel/listen for roughness/whine.
Keep all fingers attached. :twisted:
Feb 12, 2006 at 3:43 AM
QQKLTB
You are right on the money! I took it to the shop and it turned out to be the power steering pump. Thanks again for the reply
Feb 12, 2006 at 5:49 AM
PEPPERMRJ
  • 1,158 POSTS
Cool! Thanxs for the update. :D
Feb 12, 2006 at 5:51 AM
Suggested Repair
Replace the power steering pump. For a similar whine, remove the serpentine belt, briefly run the engine, and spin the pulleys by hand to check the belt, tensioner, and belt-driven accessories such as the alternator and power steering pump.
Conversation Summary
The owner of a 2002 Dodge Grand Caravan reported a whining sound when accelerating that was also audible in neutral and park. Shops disagreed about whether the transmission was at fault, and one suggested the pulley and belt area. An expert recommended checking the serpentine belt, tensioner pulley, and belt-driven accessories. The owner later confirmed the power steering pump was the cause.
