2001 Dodge Grand Caravan Belt Dressing
CGRANT
I was recently told by a mechanic that belt dressing and condistioner was not good for serpentine drive belts. Is this true nowadays? I have a 2001 Dodge Grand Caravan with 90,000 on it.
CGrant
Apr 22, 2006 at 11:37 PM
VANDRAGON
  • 298 POSTS
if your haveing trouble with the belt comeing off, then it is the tensioner or idler pully. i use Gates belts because they are ribbed on the flat side. and if you tell me it's the first time the belt has been replaced then you have been very lucky. i wouldn't use the belt dressing. it is ment for v-belts....good luck vandragon
Apr 23, 2006 at 1:44 AM
VANDRAGON
  • 298 POSTS
with all the miles on it, it could be anything that runs off the belt. the guy that does the work on your van could be rolling the belt on or missing just getting it one grove off which could make it happen.
also go here and look at all the ideas.....
www.dodgetalk.com/forums/archive/index.php/t-4450.html
Apr 23, 2006 at 7:40 AM
Suggested Repair
Do not use belt dressing or conditioner on the serpentine belt; it is intended for V-belts. If the belt is coming off, inspect the tensioner and idler pulley, confirm the belt is seated in the correct grooves, and replace a worn belt (Gates belts with ribs on the flat side were recommended). With high mileage, also check components driven by the belt.
Conversation Summary
The owner of a 2001 Dodge Grand Caravan with 90,000 miles asked whether belt dressing and conditioner are bad for serpentine belts. The expert said not to use dressing because it is meant for V-belts. If the belt comes off, check the tensioner or idler pulley, make sure the belt is not one groove off, and consider a quality replacement belt. Related driven components may also be involved at that mileage.
