1991 Dodge Grand Caravan Belt Tensioner
JSEPTER
Should I be able to move the tensioner? Do I need to loosen the nut on it first. How do I tell if the tensioner is working properly? I'm trying to replace the serpentine belt and I need to create some slack before I can get it on.
Thanks,
Jim
Jan 25, 2006 at 7:18 AM
SC1 RACING
  • 117 POSTS
you will either have a slot for a rachet to fit in or a nut. set the rachet like you are loosing a nut, and the adjuster will swing up and let you get the belt on. look for a square patern on brkt for rachet to fit in.
Jan 26, 2006 at 6:24 AM
Suggested Repair
Locate the square opening on the tensioner bracket for a ratchet, or use the nut if present. Turn the ratchet as if loosening a nut so the tensioner swings up and creates slack, then install the serpentine belt.
Conversation Summary
The owner of a 1991 Dodge Grand Caravan 3.3L asked whether the drive belt tensioner should move, whether the nut must be loosened first, and how to tell if it is working while installing a serpentine belt. The expert said to use a ratchet in the square opening on the bracket or the nut, turning it as if loosening a nut so the adjuster swings up and allows the belt to be installed.
