1999 Dodge Grand Caravan Fans Won't Run
HUNTER021664
My father has a 1999 Dodge Grand Caravan with 200K+ miles on it, and the 3.3l engine. He is having trouble with the engine overheating. Neither of the radiator cooling fans will come on. Also, the front blower for the air conditioner wasn't working. I checked the fuses in both fuse panels (in the engine compartment and under the dash, inside the van), and none were burned out. I replaced the blower relay, and the air conditioner fan motor works now, but the radiator cooling fans still won't come on. Is there a separate relay controling these two fans, and if so, where are they? Considering the age of the van, what else might be causing the trouble? Any hints will be greatly appreciated.
Oct 27, 2007 at 5:07 PM
BLACKOP555
  • 10,386 POSTS
yes there is a seperate relay for the radiator cooling fans. check that and if that is not the remedy then you should check the coolant temp sensor and the coolant temp sending unit!
Oct 28, 2007 at 1:16 AM
HUNTER021664
Thankas for the tip. Would you happen to know where the fan relays are located? I looked at the fuse panel/relay block under the hood next to the battery, and replaced the only relay I found that was labled "blower relay". That solved the air conditioner blower problem, but didn't do anything for the radiator fans. Like I said before, any hints will be appreciated. Thanks
Oct 28, 2007 at 8:54 AM
BLACKOP555
  • 10,386 POSTS
i do not know where it is located on your model sorry, all i can say is follow the electrical wires from the fans you will find it.
Oct 28, 2007 at 9:30 AM
HUNTER021664
Thanks---I'll do that
Oct 28, 2007 at 9:33 AM
Suggested Repair
Check the separate radiator cooling fan relay by tracing the wires from the fans. If the relay is not the cause, test the coolant temperature sensor and the coolant temperature sending unit.
Conversation Summary
The owner of a 1999 Dodge Grand Caravan with a 3.3L engine reports overheating because neither radiator cooling fan comes on. The fuses were good, and replacing the blower relay restored the air conditioner blower but not the radiator fans. The expert says there is a separate fan relay and, if that does not fix it, to check the coolant temperature sensor and sending unit. The relay location was unknown, so the advice was to follow the wiring from the fans.
