leak from under MiniVan
MIKEPM3S
This is a 1996 Dodge grand caravan 3.3 l
There are 2 small metal pipes under the right side of the van and one of them is leaking water. The pipes are going near the right rear tire to the front of the Van where I do not know, it seems it is going up to the engine area and then to the driver side area. I know once it stops leaking and I pour more water in the radiator it leaks again. I'm thinking it has to do with the heating and cooling system.
Oct 19, 2007 at 9:24 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a6e821ac90="mikepm3s"]This is a 1996 Dodge grand caravan 3.3 l
There are 2 small metal pipes under the right side of the van and one of them is leaking water. The pipes are going near the right rear tire to the front of the Van where I do not know, it seems it is going up to the engine area and then to the driver side area. I know once it stops leaking and I pour more water in the radiator it leaks again. I'm thinking it has to do with the heating and cooling system.[/quote:a6e821ac90]
It’s a coolant line going to the rear heater
You have two and should replace them both
easy fix
Replace them using heater hose
The correct way
buy the tube from the dealer and replace it
Both will work the same
Good luck
Oct 19, 2007 at 12:56 PM
