2003 Dodge Caravan Radiator Leak?
2003 DODGE CARAVAN
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JABADRAMO
How can I tell if the radiator is leaking?
Jun 23, 2010 at 7:06 AM
  • 110,244 POSTS
Do you see coolant under the vehicle? If so, where do you see it? Also, does it look like any hoses are loose or leaking? Finally, does the leak seem to be from the passanger side behind the tire?
Jun 23, 2010 at 2:11 PM
