1998 Dodge Grand Caravan Cooling Fan
Suggested Repair
Do not splice in an aftermarket temperature switch or relay. The cooling fan is PCM-controlled and should come on near 220 degrees. Inspect and replace the fan controller near the bottom of the radiator, a common failure, so the system operates as designed.
Conversation Summary
After a radiator replacement on a 1998 Dodge Grand Caravan 3.3L, the cooling fans did not come on at about 217 degrees, although both fans run when the A/C is on. The owner asked about fuses, relays, and adding a hose temperature switch. The expert said the fan should engage near 220 degrees, is controlled by the PCM, and should not be modified with an aftermarket sensor or relay. A fan controller near the bottom of the radiator commonly fails and should be repaired so the system works as designed.
