Thank you,
Lost Shade Tree Wanna Be
When the radio and windows are dead, test for power at the window switch and radio to see if the BCM is supplying them. The BCM is the likely cause, and the fan-relay code may come from the BCM's connection to the fan circuit.
A 2002 Dodge Grand Caravan owner reported that the radio, power windows, and other accessories stayed off for a few minutes after starting, then came on by themselves. A check engine light later set code 1491 for the radiator cooling fan relay, though the fans worked, the engine did not overheat, and the fuses were good. The expert advised testing power at the window switch or radio while the accessories are dead to confirm whether the BCM is powering them, and said the BCM is the likely fault and may also explain the fan-circuit code.
