1998 Dodge Grand Caravan No Heat
REPAIRABLE
the vehicle is a gran caravan 1998/w a 3.3L motor. the problem is when we turn the heat or defroster on it only blows cold air even after the vehicle is completely warmed up. its not overheating and the radiator may or may not be circulating properly. i have already replaced the thermostate and it didnt help. the old thermostate was bad.
Dec 4, 2006 at 4:23 AM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like the heater core is clogged. Remove both heater hoses and flush the heater core with a garden hose untill the water flows freely through it.
Hope this helps Backyardmechanic :o
Dec 4, 2006 at 4:31 AM
GARFIELD
  • 197 POSTS
You may have a problem with the heater control valve. Does your van have front and back heat and AC?
Dec 4, 2006 at 1:09 PM
BOOTDOG
  • 665 POSTS
also check to see if the your control knob is opening and closing the blender door properly. if the knob is cracked on the inside (the part which connects to the switch) then thats it. replace the knob and it should open the blender door. all the reponses u got can be the issue. good luck and let us all know :wink:
Dec 5, 2006 at 10:26 AM
Suggested Repair
Flush the heater core until water flows freely, inspect the heater control valve, and confirm the temperature knob moves the blend door; replace a cracked knob if needed.
Conversation Summary
The owner of a 1998 Dodge Grand Caravan with a 3.3L engine reports that heat and defrost blow only cold air after the engine is fully warm. The thermostat was already replaced because the old one was bad, and the engine is not overheating. Experts suggest checking for a clogged heater core, a faulty heater control valve, and a blend door that may not open because the control knob is cracked.
