2000 Dodge Grand Caravan A/C Leak
Some times you can just tighten them a little bit or blow a little freon out and it blows the trash out and it fixes it.
If it is leaking take it to a shop that can recover all the freon in the system.Go ahead and replace both of them if one is leaking the other one may start soon.
Let me know how it turns out. Hope this helped
Suggested Repair
Before replacing the evaporator, check both A/C service-port Schrader valves. Remove the caps and apply a drop of dish soap to each port; bubbling indicates a leak. A valve may sometimes seal after slight tightening or after debris is cleared. If a valve leaks, have the refrigerant recovered and replace both valve cores. A vacuum test can miss a small leak, so an electronic leak detector at the evaporator drain or vents can be used if the valves are not leaking.
Conversation Summary
The owner of a 2000 Dodge Grand Caravan reported that the A/C lost refrigerant again after the clutch and compressor were replaced. Dye testing showed no leak, and a shop found the system held vacuum despite losing about 2 lb of refrigerant over six weeks. The van has one A/C system and no separate rear evaporator. Another shop blamed a Schrader valve and quoted expensive labor, while saying the evaporator was unlikely. The expert advised leaving that shop, testing both service ports with dish soap, and replacing both valve cores after refrigerant recovery if either leaks.
