2002 Dodge Caravan Dashboard Lights Out
SAM
Hi Guys..
I've got a Dodge Caravan Sport 2002..
My dashboard lights are not working, i checked the fuse box that is located beside the engine and couldn't find a fuse named "Dashboard Fuse", i dont know if this is the right name that i should look for or there is another name for the dashboard fuse..Or if there is another fuse box..Or is there another problem!!!
Awaiting a reply..
Thanks..
Nov 25, 2006 at 8:50 AM
1BIGG1
  • 61 POSTS
there should be a fuse box under the driver side dash, look in your owners manual for the correct fuse spot and fuse type
Nov 25, 2006 at 9:24 AM
LEGITIMATE007
  • 5,121 POSTS
it would be refered to as a type of interior illumination. also its either a dimmer switch located to the left of the dash board where u turn your lights on at. or the problem is in the body control module or bcm. if you spilled something on your dash board i am almost positive its one of those areas causing the problem
Nov 30, 2007 at 2:30 AM
Suggested Repair
Check the interior illumination fuse in the driver-side under-dash fuse box using the owner's manual. Also inspect the dash dimmer switch beside the headlight control, and consider the body control module if those check out, especially if liquid was spilled on the dash.
Conversation Summary
A 2002 Dodge Caravan owner reports dashboard lights not working and could not find a dashboard fuse in the under-hood fuse box. Replies point to an interior illumination fuse in the driver-side under-dash fuse box, the dimmer switch near the headlight control, or a possible body control module fault, particularly if something was spilled on the dash.
