2002 Dodge Caravan Dash Lights Out
JAYZEHR_277
Hi there I have a Dodge Caravan 2002, 110000 kms with a 3.3L engine. I received a boost a few weeks ago and now my dash lights won't turn on making night time driving very dangerous. I looked at the fuse box to no avail and was wondering what you thought. Also, I only have the highest level blower speed for my vents and am hoping you know the reason for that as well. Thank you
Jun 7, 2007 at 9:27 AM
E40WATER12
  • 522 POSTS
First thing I would do is to make sure youre vans charging system is working at its fullest, Battery fully charged, Also youre alternator is charging, At 13.8-14 volts, Then next step is to look at fuses and shorted out wiring, Most cases you have a those common problems, Those should help you out.
good Luck.
Jun 7, 2007 at 7:08 PM
Suggested Repair
Verify the battery is fully charged and the alternator is charging at about 13.8-14 volts, then inspect the fuses and wiring for shorts.
Conversation Summary
A 2002 Dodge Caravan owner reported that the dash lights stopped working after a jump start, making night driving unsafe, and that the blower only runs on its highest speed. The expert recommended confirming the charging system, including a fully charged battery and alternator output of 13.8-14 volts, then checking fuses and shorted wiring.
