2000 Dodge Caravan Dashboard Lights Out
EDOVE
I have a 2000 dodge caravan with 110,000 miles. Last night I notice that I could not see my speedometer. the Lights are out on the dash board. Could this be just a fuse. If so can you please tell me were I can find the fuse box. the guy who look at my car wants me to bring it in but is charging me $50 just to tell me the problem.
Thanks much
Edove
Providence, RI
Dec 6, 2006 at 2:37 AM
MATHIASO
  • 1,209 POSTS
On your right side when you open the hood beside your battery, there is a black box with small rubber clamps. open it ,you will see your fuses, and a diagram that will show wich fuse is doing what job.
Dec 6, 2006 at 2:50 AM
Suggested Repair
Open the underhood fuse box on the right side beside the battery (black box with rubber clamps) and use the diagram to identify and check the fuse for the dashboard lights.
Conversation Summary
The owner of a 2000 Dodge Caravan with 110,000 miles reports the dashboard lights are out, so the speedometer cannot be seen, and asks whether a fuse is the cause and where the fuse box is. The expert says the fuse box is under the hood on the right side beside the battery, in a black box with rubber clamps, and includes a diagram showing which fuse does what.
