2000 Dodge Caravan Brake lights
71,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROBINRSIMMONS
I have just noticed that my vans brake lights are not working. I don't think that it is the actual bulbs because none of them work and I have checked fuses but it doesn't look like the fuses have anything to do with the lights. Do you have any ideas on what it could be? I don't want to take it to a dealership until I know for sure that I will have to.
Jan 3, 2008 at 3:24 AM
MERLIN2021
  • 17,250 POSTS
Look at the brake pedal, travel up the arm, you will see the stop light switch, first push it towards the front of the car, then pull up on the pedal, check for lights, if still not working, replace the switch, and redo these steps!
Jan 3, 2008 at 3:26 AM
