No lights on the instrumental cluster (Temperature Guage, Speedometer, Fuel Guage, Odometer, etc. does not lid up). I can't tell how fast I'm driving or how much gas I have. This blackout has happened before but I would allow the van to sit for a few hours and start it up again with no problem. There seem to be no problem with the information center at this moment. Do I need to replace the entire instrument cluster or can I just have the bulb replaced? Is this something I can do myself? Please help. Thank you!
1997 Dodge Caravan Cluster Lights Out
Good luck
Suggested Repair
Because all cluster lights fail and return together, test the yellow/black wire at the back of the headlight switch for power with the headlights on while the dash lights are out. That wire signals the body control module to turn on the dash lights. If power is present, suspect the BCM rather than individual bulbs.
Conversation Summary
The owner of a 1997 Dodge Caravan reports that the instrument cluster lights, including the gauges, speedometer, fuel gauge, and odometer, go dark all at once and later return after the van sits. One reply suggested replacing the cluster bulbs. After the owner noted that they fail and return together, the expert advised testing the yellow/black wire at the headlight switch for power when the lights are out; if power is present, the body control module may be the cause.
